GCX Worksheet
Christoffer.N
GCX Worksheet
Post by Christoffer.N »
Hi! I need confirmation on my Worksheet as you can see below
Current I follow the (Pedals, FX Loop, 3 Channel Amp Switching) worksheet.
Now i wanna switch between my 2 amps, the JC-120 and my Boogie!
I followed the A/B switching example 2 from the manual, but the manual also say:
Important: GCX audio loops are for instrument and line level signals only. Using them to switch amplifier or speaker outputs will severely damage your GCX.!???
Regards Chris!
Re: GCX Worksheet
Looks good to me!
The warning you mention is saying to never run the Speaker Output of an amp into the GCX. You have Loop 4 selecting which amplifier will receive the guitar signal, no problems there.
