PPAC / GCX+GCP
PPAC / GCX+GCP
I see that the PPAC can be used to power the GCX/GCP. Where do I find the cable to to go from the GCX multi pin to the barrel for connecting to the PPAC?
Re: PPAC / GCX+GCP
you can easily build your own cable, by cutting the original gcx cable and mounting a small barrel for the PPAC...
mibu
web shop: www.urmascapaturma.ro
youtube channel: http://www.youtube.com/user/mibutzu
Re: PPAC / GCX+GCP
I thought so, but need to know the wiring for the GCX four pin cable to the barrel.
Re: PPAC / GCX+GCP
the two pins on the left side goes together and the two on the right also together. no + and - because it's AC...
mibu
