Boss gr-55 in GCX
hobelixx
Boss gr-55 in GCX
Post by hobelixx »
how put boss gr-55 in one of the gcx 's loops? :D
Tks
Re: Boss gr-55 in GCX
I suppose that really depends on what you are attempting to do. If you want to A/B between the GR-55 Guitar Output and main effect Output then I would suggest connecting it as follows...
1. GR-55 Guitar Output to the In of a GCX Loop.
2. GR-55 effect Output (Mono) to the Return of the same GCX Loop.
3. Out of this same GCX Loop to the input of your amp.
