VOLTAGE CHANGE
florchiza
VOLTAGE CHANGE
Post by florchiza »
Hello , i have to bring the voltage from 220V to 120V , this thing will work?
Sin título.jpg (98.85 KiB) Viewed 3367 times
Re: VOLTAGE CHANGE
That should be fine.
florchiza
Re: VOLTAGE CHANGE
Post by florchiza »
For a voodoolab plus 2? , it should work with no problem ?
Re: VOLTAGE CHANGE
A fully loaded Pedal Power 2+ will consume less than 20 Watts. If you will be powering anything from the Courtesy Outlet add its Wattage rating to to find your minimum need.
The step down you show is rated for 50 Watts.
