Pedals and power
bigtrex76
Pedals and power
Post by bigtrex76 »
Ok so i have an original pedal power and a pedal power 2 plus.
I have the eventide h9, the whammy V (dc power) and a tc electronic flash back x4 (not really using but figured i would insert it). Now i currently have the H9 power feom the voodoo 2 with out lets 5&6 using a doubler and the correct tip (works fine). I can power the x4 from seemilngly any output and it works however i cannot get the whammy V to work only via the wall warr it came with. Am i missing something, do i not have enough POWAH?
Rex
Wah
Whammy
PitchBlack
phase
flange
Delays OD
Jcm 800
Blackstar HT 50
5150 signature peavey & 50 watt 5153
http://www.myspace.pallor
http://www.myspace.com/falseflag7
bigtrex76
Re: Pedals and power
Post by bigtrex76 »
Well....sometimes you just gotta say f it, and get another power supply. Digital pedal power is now in my hands, should cover the h9, whammy 5 and flashbackx4
Wah
Whammy
PitchBlack
phase
flange
Delays OD
Jcm 800
Blackstar HT 50
Sorry for the lateness here!
Yea, I'm surprised you had as much success as you did! The Pedal Power Digital is certainly the better choice and it will absolutely power the H9, Whammy 5, and Flashback X4 using any of the 9V outputs.
