Pedal Power II PLus - TS9 Ibanez
Hello, I have a consultation, I would want to connect the pedal tubscreamer TS9 Ibanez, to the pedal power II plus, but not in which entrance to connect it, and if the DIP Switch must be in NORMAL or in ON. Thank you very much Pepe
Re: Pedal Power II PLus - TS9 Ibanez
Any output set to Normal will power the TS-9 using the standard barrel connector cables provided with the Pedal Power.
Muchas gracias!!!
Thanksssss!!!
Thanksssss!!!
