Hi Josh
Is it possible to power a Nova Delay from the PP2+? Can it be done from a single outlet ie 5 & 6?
The Nova Delay manual says- "The Nova Delay require 12V DC 300 mA. Use the power supply provided in the product box or a power supply with similar specifications"
I am asking in advance of buying one for my pedalboard. I have already used the Courtesy outlet for a pedal requiring AC!
Best Regards
Paul A
PP2+ and Nova Delay
Re: PP2+ and Nova Delay
Hi Paul, yes you can power a Nova Delay. I use a current doubler cable from from outputs 5 & 6 with the DIP switches set to ON on the Pedal Power. I have been doing this for over a year with no issues whatsover. Its the green cable in the picture below:
- Attachments
- dscn0647640x480ih9.jpg (82.71 KiB) Viewed 26312 times
Connoisseur of good tone.
http://www.guitarpedals.co.nz
T-Rex sell this cable - may Voodoo Labs could start making it too!
Thanks for the reply.
That might leave me a couple of outlets short for the 9v pedals but I'm sure I can double up somewhere with out ground loop problems.
Yes you can use a daisy chain from one of the Isolated Outputs or a Y cable. Also a friend of mine has been powering the Nova from just output 5 (Dip switch ON), giving it 250mA, his works fine too. My advice try both!Paul A wrote:Thanks for the reply.
- Site Admin
You can power from a single output if you use 5 or 6 and make sure the DIP switch is on (away from "normal"). The current demand is a little high, so I wouldn't run another TC Nova pedal in the other output.Trueman wrote: Yes you can use a daisy chain from one of the Isolated Outputs or a Y cable. Also a friend of mine has been powering the Nova from just output 5 (Dip switch ON), giving it 250mA, his works fine too. My advice try both!
Josh Fiden
Founder / CEO
Hi Josh. My name is Ettore, from ItalyYou can power from a single output if you use 5 or 6 and make sure the DIP switch is on (away from "normal"). The current demand is a little high, so I wouldn't run another TC Nova pedal in the other output.
Is that true also for an old Tc Electronic vintage delay (it seems to have the same power request)?
Ettore
- Site Admin
Hi Ettore,
I don't know which delay you have so I don't know if it will work. Sorry.
Josh
Josh
The TC Vintage Delay is the axact same pedal as the T-rex Replica (on the inside - on the outside the colour is different ) - I think you can find the answer in the tread about this pedal here: http://www.voodoolab.com/forum/viewtopic.php?f=7&t=101srv69 wrote:Hi Josh. My name is Ettore, from ItalyYou can power from a single output if you use 5 or 6 and make sure the DIP switch is on (away from "normal"). The current demand is a little high, so I wouldn't run another TC Nova pedal in the other output.
Ettore
/Michael
Josh Fiden wrote:You can power from a single output if you use 5 or 6 and make sure the DIP switch is on (away from "normal"). The current demand is a little high, so I wouldn't run another TC Nova pedal in the other output.Trueman wrote: Yes you can use a daisy chain from one of the Isolated Outputs or a Y cable. Also a friend of mine has been powering the Nova from just output 5 (Dip switch ON), giving it 250mA, his works fine too. My advice try both!
Josh Fiden
Founder / CEO
hmmmmm......what if im running a DD-20 in the other output (#5) can i still run the TC nova delay on a single output? or do i have to use the power adapter it comes with and plug into the back of the PP2+
