Hi you all.
If anyone is interested, i've inluded a link to the SYX file for using the Kemper Profiling Amp in performance mode.
http://www.fixxxer.info/img/kemper/kemper_gcp.syx
Please feel free to use the formidable editor to adjust the syx-file to your liking.
https://gcproeditor.com/
Midi Channel is set to 1
I have setup 7 banks (bank 0 to bank 6) with 4 slots each and mapped the correct program change to match the 5 slots Kemper layout to the 4/10 button setup of the Ground Control Pro (the fifth Kemper slot is deactivated on the Kemper performance)
Each bank is:
- 1: Clean
- 2: Rhythm
- 3: Lead I
- 4: Lead II
Pedal 1is active and mapped to CC 1 for wah (with the amazing auto-engage from Kemper).
Pedal 2 is active and mapped to CC 7 for volume
The instant acces buttons:
- IA 1: Kemper Tempo - CC30 - Momentary >> to allow the excellent beat scanner and correct tap-tempo for the Kemper)
- IA 2: Kemper Stomp D - CC20 - Latching
- IA 3: Kemper Stomp X - CC22 - Latching
- IA 4: Kemper Morphing - CC11 - Latching
- IA 5: Kemper Mod - CC24 - Latching
- IA 6: Kemper Delay (with tails) - CC27 - Latching
- IA 7: Kemper Stomp B - CC18 - Latching
- IA 8: Kemper Stomp C - CC19 - Latching
To enable the import to your GCP, you need to use Midi Mon and use the Send Syx function which will allow you to upload the attached syx file to your Kemper
http://www.fixxxer.info/img/kemper/MidiMonSetup.exe
Hope this is usefull for someone.
I do this because ot the excellent customer service provided by Voodoo Labs!
Kindest of Regards,
Tijl - Belgium
GCP and Kemper setup
Re: GCP and Kemper setup
Right on! Thanks for sharing!
Dude - where did you get those labels?
