Best-Tronics Pro Audio // Dual Pedaltrain Setup
BTPA USA
Post by BTPA USA »
Here is a two board setup we did. The Pedaltrain Pro was the artists' main board. This is the board that he would use regularly. Occasionally, he would want to use a Wah and additional Wah/Expression pedal, which is what the peripheral board is for. The Classic 2 also houses a separate signal chain for use with acoustic gigs/songs. The Pedaltrain Classic 2 features two separate panels. The rear panel is for the electic guitar signal and linking to the main board. The side panel is dedicated to the acoustic signal, featuring a Direct Out from the Fishman to FOH.
http://www.btpa.com
Professional Audio Cables & Rig/Pedalboard Integration
100% Custom - 100% Made in the USA
