line 6 pod pro xt
felipe_esp
line 6 pod pro xt
Post by felipe_esp »
hi guys: i´m having problems with my pod pro xt, i can´t get a right sound out of it, maybe i´m not setting this up ok, not sure even looking into the users guide of my pod which is the right input or output to use.
the loop goes like this:
ada mp1
G major
pod pro xt
each one of these goes to the gcx, then into the marshall el34 50/50
thank you!!
Re: line 6 pod pro xt
Judging from a picture of the back panel I'd say you would want to use the Line Level Input, and one of the Unbalanced Analog Out jacks. You may need to change some settings in the POD to get the Line in to work and to disable any Speaker Simulation.
felipe_esp
JohnClark wrote:Judging from a picture of the back panel I'd say you would want to use the Line Level Input, and one of the Unbalanced Analog Out jacks. You may need to change some settings in the POD to get the Line in to work and to disable any Speaker Simulation.
thank you so much.
i´ll look into it.
greetings from Chile.
