I've seen in numerous places that the PP2+ can power one or even two of the Evetide Factor pedals, using the Line6 adapter and using 5 or 6 with the switch flipped- I get it. My question is this can the PP2 (not the plus, just the "2") also safely power up to 2 Eventide Factor boxes since the 2 can power up the Line6 pedals as well?
Also, can the PP2 power the TC Nova Drive? Currently my PP2 is only powering a Teese RMC3 wah and a Sonic Research ST200 tuner, so the isolated outputs are far from maxed out. Cutting back on one or especially two wall warts would be really advantageous.
...all replies welcome, especially from a VoodooLab moderator/employee like John Clark, Josh or whoever's monitoring the forum today.
PP2 (not PP2+) and Eventide Factor pedals question
Re: PP2 (not PP2+) and Eventide Factor pedals question
I would like to know as well. I am planning on doing the exact same thing with my old PP2.
No one knows this, huh?
Anyone from VL want to take a stab at this?
Hey, can I get an answer to this simple question?
Hello- John Clark-- anyone?
It likely will not work reliably to try to power two of the Eventide pedals from a Pedal Power 2. You can reliably power one using a parallel cable from outputs 5 and 6 switched away from Normal and the other from the Courtesy Outlet using the supplied adapter.
John- Thank you!
