...because the ones that came with my PP2+ dont seem to fit.
If I need to order special power cords - can you please send me the link so that I can order 2 of them (I have two Pedal Switchers that I need to power)
Thank you
Does the PP2+ come w/connecter cords for Pedal Switchers?
Re: Does the PP2+ come w/connecter cords for Pedal Switchers?
You need to use the 2.5mm RED Barrel Connectors. The Pedal Switchers actually require AC Power not DC, but you can use outputs 5 OR 6 in Line 6 Mode i.e. set the dip switches to non-normal
Connoisseur of good tone.
http://www.guitarpedals.co.nz
